# This script is based on a Maple session by Bruno Salvy (March 4, # 2003), later updated and simplified: no didactic information here, # only what is used in the Coq proof. # Convention: This script has one section for each sequence to be # considered, which start by '### Sequence x_{...} = '. # When this sequence is explicit or is obtained by a closure # computation of type plus or times, the section stores the # corresponding operators into a file 'ann_x.v'; when it is obtained # by creative telescoping, say x is the sum of y over some domain, the # pairs (P, Q) are stored into the generated file for y, 'ann_y.v', # before renormalizing the Ps and storing them into the file for x, # 'ann_x.v'. # Summary of the file (listing the closures): # * c_{n,k} = explicit hypergeometric term # * a_n = \sum_{k=0}^n c_{n,k} # * d_{n,k,m} = explicit hypergeometric term # * s_{n,k} = \sum_{m=0}^k d_{n,m} # * z_n = explicit special sequence # * u_{n,k} = s_{n,k} + z_n # * v_{n,k} = u_{n,k} * c_{n,k} # * b_n = \sum_{k=0}^n v_{n,k} # We use Algolib, which is distributed in the git repository, libname := ".", libname: # as well as converters from Maple to SSR notation. read "maple2ssr.mpl": # Help functions. rec_order := proc(rec, u, x, $) max( map(p -> op(p) - x, map2(select, has, indets(rec, specfunc(anything, u)), x)) ) end proc: to_skew_poly := proc(rec, u, xs, Sxs, $) local T := table(); local fcalls := indets(rec, specfunc(anything, u)); local i, shifted_u, x; for i to nops(xs) do T[xs[i]] := Sxs[i] end do; fcalls := map( shifted_u -> shifted_u = mul(T[x]^(op(select(has, shifted_u, x)) - x), x = xs), fcalls); eval(rec, fcalls) end proc: ### Define sequence to prepare evaluations. c_nk := binomial(n,k)^2 * binomial(n+k,k)^2: a_n = Sum(eval(c_nk, k = l), l = 0..n): d_nkm := (-1)^(m+1) / (2 * m^3 * binomial(n,m) * binomial(n+m,m)): s_nk := Sum(d_nkm, m = 1..k): z_n := Sum(1/l^3, l = 1..n): u_nk := s_nk + z_n: v_nk := u_nk * c_nk: b_n := Sum(eval(v_nk, k = l), l = 0..n): ### Sequence c_{n,k} = explicit hypergeometric term. extra1 := [n], [Sn], c: extra2 := [n, k], [Sn, Sk], c: extraA := extra2, mode = tdeg(Sn, Sk): extraP := extra1, mode = "P": extraQ := extra2, mode = "Q": maple2ssr:-pp_skew_poly( Sn - factor(normal(eval(c_nk, n = n + 1) / c_nk, expanded)), extraA ): maple2ssr:-write(%, append = false, file = "ann_c.v"); maple2ssr:-pp_skew_poly( Sk - factor(normal(eval(c_nk, k = k + 1) / c_nk, expanded)), extraA ): maple2ssr:-write(%, file = "ann_c.v"); ### Sequence a_n = \sum_{k=0}^n c_{n,k}. # This summation is over natural boundaries, as shown by inhom = 0 below. CT := Mgfun:-creative_telescoping(c_nk, n::shift, k::shift)[1]: ct := eval(CT, {_F = unapply(c_nk, n), _f = unapply(c_nk, n, k)}): inhom := normal(limit(ct[2], k = n+3)) - eval(ct[2], k = 0); maple2ssr:-pp_skew_poly(to_skew_poly(CT[1], _F, [n], [Sn]), extraP): maple2ssr:-write(%, file = "ann_c.v"); maple2ssr:-pp_skew_poly(to_skew_poly(CT[2], _f, [n, k], [Sn, Sk]), extraQ): maple2ssr:-write(%, skip_line = false, file = "ann_c.v"); old_module := "annotated_recs_c": maple2ssr:-pp_in_terms_of([1], [n], a, old_module, ["P_flat"], "Sn2"): maple2ssr:-write(%, append = false, skip_line = false, file = "ann_a.v"); ### Sequence d_{n,k,m} = explicit hypergeometric term. extra2 := [n, k], [Sn, Sk], d: extra3 := [n, k, m], [Sn, Sk, Sm], d: extraA := extra3, mode = tdeg(Sn, Sk, Sm): extraP := proc(i, $) extra2, mode = "P" || i end proc: extraQ := proc(i, $) extra3, mode = "Q" || i end proc: maple2ssr:-pp_skew_poly( Sn - factor(normal(eval(d_nkm, n = n + 1) / d_nkm, expanded)), extraA ): maple2ssr:-write(%, append = false, file = "ann_d.v"); maple2ssr:-pp_skew_poly( Sk - factor(normal(eval(d_nkm, k = k + 1) / d_nkm, expanded)), extraA ): maple2ssr:-write(%, file = "ann_d.v"); maple2ssr:-pp_skew_poly( Sm - factor(normal(eval(d_nkm, m = m + 1) / d_nkm, expanded)), extraA ): maple2ssr:-write(%, file = "ann_d.v"); ### Sequence s_{n,k} = \sum_{m=0}^k d_{n,m}. # This summation is not over natural boundaries as it is an indefinite one. CT := Mgfun:-creative_telescoping(d_nkm, [n::shift, k::shift], m::shift): # CT[1][1] expresses \Delta_n; CT[2][1] expresses \Delta_k. # CT[2][2] is 0. # Operators on sum from CT[1]. eval(CT[1][2], _f(n, k, m) = d_nkm): eval(%, m = k + 1) - eval(%, m = 1): inh := map(normal@expand, %, expanded): convert(Mgfun:-dfinite_expr_to_sys(inh, f(n::shift, k::shift)), list): # Each recurrence Ps_[i] is certified by Qs_[i]. Ps_ := collect( eval(%, f = unapply(d(n + 1, k, m) - d(n, k, m), n, k)), d, normal): Qs_ := collect( eval(%%, f = unapply(eval(CT[1][2], _f = d), n, k)), d, normal): # Operators on sum from CT[2]. inh := factor(normal(expand(eval(d_nkm, m = k + 1)), expanded)): convert(Mgfun:-dfinite_expr_to_sys(inh, f(n::shift, k::shift)), list): # Each recurrence Ps__[i] is certified by Qs__[i]. Ps__ := collect( eval(%, f = unapply(d(n, k + 1, m) - d(n, k, m), n, k)), d, normal): Qs__ := collect( eval(%%, f = unapply(0, n, k)), d, normal): Ps := map(op, [Ps_, Ps__]): Qs := map(op, [Qs_, Qs__]): N := nops(Ps): for i to N do eval(Qs[i], d = unapply(d_nkm, n, k, m)); eval(%, m = m + 1) - %; eval(Ps[i], d = unapply(d_nkm, n, k, m)); print(i = normal(%% - %, expanded)) end do: Ps := map(to_skew_poly, Ps, d, [n, k], [Sn, Sk]): Qs := map(to_skew_poly, Qs, d, [n, k, m], [Sn, Sk, Sm]): for i to N do maple2ssr:-pp_skew_poly(Ps[i], extraP(i)); maple2ssr:-write(%, file = "ann_d.v"); maple2ssr:-pp_skew_poly(Qs[i], extraQ(i)); maple2ssr:-write(%, skip_line = evalb(i < N), file = "ann_d.v") end do: # Normalize the set of Ps for s_{n,k} by a Gröbner-basis computation. Alg := Ore_algebra:-shift_algebra([Sn, n], [Sk, k]): MOrd := Groebner:-MonomialOrder(Alg, tdeg(Sn, Sk)): bPs := Groebner:-Basis(Ps, MOrd): Groebner:-LeadingMonomial(bPs, MOrd); bPs_names := map(maple2ssr:-pp_name_of_monomial, %, [Sn, Sk]); Groebner:-LeadingMonomial(Ps, MOrd); Ps_names := [seq("P" || i || "_flat", i = 1..nops(Ps))]; # Transformation rules: GB in terms of old generators. rules := [ gb[1] = gens[4], gb[2] = gens[3], gb[3] = (n+k+2)*gens[1] + k*(2*n+3)*(n-k)*gens[3] ]: # Verifies them in Maple. eval(rules, {seq(gb[i] = bPs[i], i=1..3), seq(gens[i] = Ps[i], i=1..4)}): map(evalb@expand, %); old_module := "annotated_recs_d": for i to 3 do [seq(coeff(op(2, rules[i]), gens[j]), j=1..4)]; maple2ssr:-pp_in_terms_of(%, [n, k], s, old_module, Ps_names, bPs_names[i]); maple2ssr:-write(%, append = evalb(1 < i), file = "ann_s.v") end do: extra2 := [n, k], [Sn, Sk], s: extraA := extra2, mode = tdeg(Sn, Sk): for i to 3 do maple2ssr:-pp_skew_poly(bPs[i], extraA); maple2ssr:-write(%, skip_line = evalb(i < 3), file = "ann_s.v") end do: ### Sequence z_n = \sum_{k=1}^n 1/k^3. extra1 := [n], [Sn], z: extraP := extra1, mode = tdeg(Sn): inhom := (n+1)^3 * (_f(n+1) - _f(n)) - 1: collect(eval(inhom, n = n + 1) - inhom, _f, factor): ann_z := to_skew_poly(%, _f, [n], [Sn]): maple2ssr:-pp_skew_poly(ann_z, extraP): maple2ssr:-write(%, append = false, skip_line = false, file = "ann_z.v"); ### Sequence u_{n,k} = s_{n,k} + z_n. # Find GB for s in terms of ann_z and Delta_k. This will show that # ann_s is a subideal of ann_z (viewed w.r.t. n and k). Therefore, # ann_u is taken to be equal to ann_s. Groebner:-NormalForm(ann_z, bPs, MOrd); map(Groebner:-NormalForm, bPs, [ann_z, Sk - 1], MOrd); divide_by_ann_z_and_Delta_k := proc(L, $) local R := eval(L, Sk = 1); local Q2 := normal((L - R) / (Sk - 1)); local Q1 := normal(R / ann_z); collect([Q1, Q2], {Sn, Sk}, distributed, factor); end proc: rules := [seq(divide_by_ann_z_and_Delta_k(bPs[i]), i = 1..3)]: #old_module := "annotated_recs_d": for i to 3 do #rules[i]; # What follows breaks as pp_in_terms_of only accepts # rational-function coefficients. # maple2ssr:-pp_in_terms_of(%, [n, k], s, old_module, ["ann_z", "Delta_k"], bPs_names[i]); # maple2ssr:-write(%, append = evalb(1 < i), skip_line = evalb(i < 3), file = "ann_s.v"); # The following is to help write the proof manually. gb[i] = rules[i][1] * Ann_z + rules[i][2] * Delta_k end do; extra2 := [n, k], [Sn, Sk], w: maple2ssr:-pp_skew_poly(rules[1][2], extra2, mode = "gb1_cf_of_Delta_k"): maple2ssr:-write(%, append = false, file = "ann_u.v"); maple2ssr:-pp_skew_poly(rules[2][2], extra2, mode = "gb2_cf_of_Delta_k"): maple2ssr:-write(%, file = "ann_u.v"); maple2ssr:-pp_skew_poly(rules[3][1], extra2, mode = "gb3_cf_of_Ann_z"): maple2ssr:-write(%, file = "ann_u.v"); maple2ssr:-pp_skew_poly(rules[3][2], extra2, mode = "gb3_cf_of_Delta_k"): maple2ssr:-write(%, file = "ann_u.v"); # Express that u_nk has the same annihilator as s_nk. old_module := "annotated_recs_s": maple2ssr:-pp_in_terms_of([1], [n, k], u, old_module, ["Sn2_lcomb"], "Sn2"): maple2ssr:-write(%, file = "ann_u.v"); maple2ssr:-pp_in_terms_of([1], [n, k], u, old_module, ["SnSk_lcomb"], "SnSk"): maple2ssr:-write(%, file = "ann_u.v"); maple2ssr:-pp_in_terms_of([1], [n, k], u, old_module, ["Sk2_lcomb"], "Sk2"): maple2ssr:-write(%, file = "ann_u.v"); ### Sequence v_{n,k} = u_{n,k} * c_{n,k}. sys_for_u_nk := map(Ore_algebra:-applyopr, bPs, _f(n, k), Alg): sys_for_c_nk := Mgfun:-dfinite_expr_to_sys(c_nk, _f(n::shift, k::shift)): sys_for_v_nk := Mgfun:-`sys*sys`(sys_for_u_nk, sys_for_c_nk): extra2 := [n, k], [Sn, Sk], v: extraA := extra2, mode = tdeg(Sn, Sk): map(to_skew_poly, sys_for_v_nk, _f, [n, k], [Sn, Sk]): # Sort this Maple set for reproducibility. sort( convert(%, list), (a, b) -> Groebner:-TestOrder(a, b, tdeg(Sn, Sk)) ): defs := map(maple2ssr:-pp_skew_poly, %, extraA): for i to 3 do maple2ssr:-write(defs[i], append = evalb(1 < i), file = "ann_v.v") end do: ### Sequence b_n = \sum_{k=0}^n v_{n,k}. infolevel[Mgfun]:=5: CT := Mgfun:-creative_telescoping(LFSol(sys_for_v_nk), n::shift, k::shift)[1]: ct := eval(CT, {_F = unapply(v_nk, n), _f = unapply(v_nk, n, k)}): # This summation is over natural boundaries, as shown by inhom = 0 below. # Just, the computation is more involved than just calling limit. inhom := eval(ct[2], k = n+5) - eval(ct[2], k = 0): su_Sum := map( proc(s, $) local f := op(1, s); local lb := op([2, 2, 1], s); local ub := op([2, 2, 2], s); local pv := op(indets(ub)); local sv := op([2, 1], s); local i; s = Sum(f, sv = lb..pv) + add(normal(expand(eval(f, sv = pv + i))), i = 1..ub - pv) end proc, select(has, indets(inhom, function), Sum) ): su_binomial := map( proc(b, $) b = normal(expand(b)) end proc, select(hastype, indets(inhom, function), specfunc(anything, binomial)) ): eval(inhom, su_Sum union su_binomial): eval(%, binomial = proc(a, b, $) `if`(type(b, negint), 0, 'binomial'(a, b)) end proc): inhom := collect(%, {Sum, binomial}, normal); extra1 := [n], [Sn], v: extra2 := [n, k], [Sn, Sk], v: extraA := extra2, mode = tdeg(Sn, Sk): extraP := extra1, mode = "P": extraQ := extra2, mode = "Q": maple2ssr:-pp_skew_poly(to_skew_poly(CT[1], _F, [n], [Sn]), extraP): maple2ssr:-write(%, file = "ann_v.v"); maple2ssr:-pp_skew_poly(to_skew_poly(CT[2], _f, [n, k], [Sn, Sk]), extraQ): maple2ssr:-write(%, skip_line = false, file = "ann_v.v"); old_module := "annotated_recs_v": maple2ssr:-pp_in_terms_of([1], [n], b, old_module, ["P_flat"], "Sn4"): maple2ssr:-write(%, append = false, skip_line = false, file = "ann_b.v");
